bob_b1's avatar
bob_b1
The Norcold broke (again) and I am going with a Residential.
My Norcold 682 model has had the cooling unit replaced once, the eyebrow board once, the temp probe once and the ignition module twice. The ignition module is now shot and I refuse to put more good money into bad.
I found a Vassani 10-cu ft. model from Home Depot that will fit the opening. I bought a Xantrex 1000W modified sine wave inverter with remote power switch and bought a Xantrex Automatic Transfer switch.
Two Southco Grabber Catch Latches have been ordered (as per suggestions here) to keep the doors shut while underway.
A 3/8" gas cap and some wood trim were purchased from Home Depot.
I am hoping to use the existing 2-battery bank to power the fridge and am really looking forward to having a reliable fridge for a change.
The parts are all on order and I would like to tackle the project this weekend.
As there seems to be a lot of postings on the trim work for the fridge, I will try to post my experience on the setup involved prior to the fridge:
  • The gas line will need to be capped.
  • The inverter install.
  • The transfer switch install.
  • The removal of the old fridge.
  • The sealing of the old vents (if necessary).
***Edit March 24 2014: As promised, I am posting a follow up. See my post from today.
