bob_b1's avatar
bob_b1
The Norcold broke (again) and I am going with a Residential.
My Norcold 682 model has had the cooling unit replaced once, the eyebrow board once, the temp probe once and the ignition module twice. The ignition module is now shot and I refuse to put more good money into bad.
I found a Vassani 10-cu ft. model from Home Depot that will fit the opening. I bought a Xantrex 1000W modified sine wave inverter with remote power switch and bought a Xantrex Automatic Transfer switch.
Two Southco Grabber Catch Latches have been ordered (as per suggestions here) to keep the doors shut while underway.
A 3/8" gas cap and some wood trim were purchased from Home Depot.
I am hoping to use the existing 2-battery bank to power the fridge and am really looking forward to having a reliable fridge for a change.
The parts are all on order and I would like to tackle the project this weekend.
As there seems to be a lot of postings on the trim work for the fridge, I will try to post my experience on the setup involved prior to the fridge:
  • The gas line will need to be capped.
  • The inverter install.
  • The transfer switch install.
  • The removal of the old fridge.
  • The sealing of the old vents (if necessary).
***Edit March 24 2014: As promised, I am posting a follow up. See my post from today.
  • MNtundraRet wrote:
    With only 2 batteries you are going to be in for disappointment for any camping without shore-power. Especially with a 10 c.f. unit.
    You are probably very right, but I have found another poster here that has had success using two batteries.
    Here is why I think that it might work (check my math):
    According to the yellow sticker, this Fridge uses 312kw/yr.
    That is 312,000 watts per year.
    That is 854.7 watts per day.
    or 35.6 watts per hour
    or .29 amps per hour (remember this thing isn't running all the time)
    or 2.9 amp per hour at 12 volts.
    One of those 12V overhead lights will suck down that much juice.
    Running it for 10 hours over night should use 30 amp hours. My pair of batteries are rated at 245 amp hours or 123 usable amp hours. I think that I could make it work.
    I'll find out soon enough, I'm sure:B
  • Could go for a 12v compressor fridge/freezer.
  • With only 2 batteries you are going to be in for disappointment for any camping without shore-power. Especially with a 10 c.f. unit.
    If you stick to shore-power you will be happy. I just hope they come up with something better before my current 6 c.f. unit goes belly up. We can deal with the thermistor sometimes acting up and leaving the unit running "always on" by just turning off for about 4 hours, and then restarting.
  • dave17352 wrote:
    I would switch that inverter out for a 2000 watt.
    That is good advice. I must have got lucky. I just looked up the specifications on the 1000W inverter and it has a 2000W surge capacity. So I should be good.
  • Trim on an RV is no problem anymore. Buy some molding. Take a piece of the molding and one of your cupboard doors into your local paint store.Tgey can shoot it for color and mix some stain to match. I had some matching done on my previous TT at Sherwin Williams.
    I would be more concerned with fridge power requirements. I would check before purchase. Some are better than others.
  • I would switch that inverter out for a 2000 watt. I made the same change only I used a Haier refer. You would be surprised at the power draw when the compressor kicks on. I have the 2000 watt inverter and I am glad I do. Not saying the 1000 watt inverter won't work but the difference in cost is not that much. Since yours is on order you could just switch them out. JMHO
    I do love my haier fridge though, its a great change. Do not remove the defrost from the cycle. I did and I ended up buying a new defrost timer and re installing it. I was amazed at how much frost can build up on humid summer days. Which I was warned about removing right here on the forum but I didn't listen!!
