MrRchitty
Aug 02, 2012Explorer
PrivatePilot wrote:
It's a twist lock style plug. The bare plugs can be found at most electrical supply stores if you want to use it, or make an adapter.
I sort of wish that they had used a regular electrical plug that was just able to supply more than 15 A instead of using that funny plug though, as there's lots of times that I've needed more amps than what one generator will supply (air Compressor for example) but I'm not actually able to plug the draw into the parallel kit due to the lack of a standard receptacle.
One of these days I'm just going to go buy a twist lock adapter, a small length of heavy cord, and a regular 15 amp female plug and make an adapter.
Then again on second thought one of the RV 30>15 amp adapter plugs would probably be cheaper.
I made my own. I bought a 10 gauge contractor cord (25') and cut the 15 amp male from it. I put a 30 amp male twist lock on it. I also cut a small piece off, put a male 30 amp twist lock on one side and a square box with a 20 amp rated switch and 20 amp receptacles. The switch cuts the receptacles. I also made my own adapter cord so I can plug this stuff into 15 amp receptacles. This set up can go on my Champion inverter sets or my Champion 3500 watt set up. I will, if running for a long period, attach 2 15 amp fused power strips.
Let me see if I can find a picture. (out camping right now)
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
