chiefward
Aug 16, 2012Explorer
"I just finished following the Tech Bulletin procedure to eleminate the "burp" without complete success. It did help but did not eleminate the burp intirely. Have any of you done this procedure with "complete" success? I did not have and couldn't find a .018 drill bit so I used a tiny wire and air pressure to clean the jet. A hint I learned the hard way for those of you that plan to do this procedure, remove the screw inside the Fuel Control Knob, take the knob out, and you won't have to remove the gas tank. You can just push the tank aside to get to the carburator. "
Champion sent me a new carburator (which I haven't put on yet) that hopefully will fix my burp problem.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
