MrRchitty
Sep 03, 2012Explorer
Hybridhunter wrote:Wayne Dohnal wrote:Hard to fathom why my 1200 watter handled this load with aplomb, and the 1600 watter won't even try. I was again considering the 2000, now that I have the PD, but this was way to frustrating. ...The answer is easy once you know what it is :-) It's a combination of power factor, poor regulation of small synchronous generators, and the PD converters having a weak output with less than .
I understand that and that is not what I was suggesting. I fully understand the PF and the dynamic nature of the current draw from converters. My point was, what is the likely use for a 2000 watt inverter gen? RVing! Why not make a unit that can reliably tackle the most BASIC task that it will face. Techno Mumbai jumbo aside... It is good to look at that aspect, but this thread has become a crutch of excuses, never need until Champion decided to compete with other similarily model numbered generators.
It plain old does not work reliably under a normal, everyday situation. It has but one task, to reliably put out power within it's ratings. The newer models should have been "de-rated". The fact that they aren't is more telling than the long winded explanations blaming the marketing department.
What is the voltage of the batteries before you recharge them? For kicks and giggles...what is the voltage of your Champion Inverter with and without a load?
If you can, find a smaller tool like an electric drill or small compressor. Just curious what the voltage drops to when initially loaded.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
