bondebond
Sep 10, 2012Explorer
Unyalli wrote:You can thank the EPA for making it harder and harder to rejet. They've required a cover over one of the jets anyway, that has to be drilled out or forcefully removed.
I don't seem to find any discussion of jetting in this very informative thread. I live at 6200 feet and will probably never be below 5000ft when camping. I would like to install high altitude jetting, anyone else?
Jeff
See here and here for jet information. There isn't anything because it's not available unless you take it apart and find someone to help you out locally or via the web.
I used one at 9,500 ft. and was really wishing I had been able to lean it out a bit as it really ran rich. I recall looking at the carb one time when I had the covers off and thought I saw "Champion" on the carb, so it's not likely to use jets off of a Mikuni or other manufacturer, but you might start there.
Contact Champion if all else fails.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
