professor95
Oct 14, 2012Explorer
radar46 wrote:
Trying to clean the spark arrestor on my 7 month old CPE2000i but after removing the clamp and outer ring with screen I can't seem to get the S.A. out of the exhaust tube. I am wondering if tapping it with a hammer would help or just cause damage? Any suggestions?
Thanks,
Radar.
I don't know if you have reviewed the maintenance procedure in the manual or not - just in case you have not, you can find it here on page 14.
If you tap it with a hammer you may bend the pipe. I would suggest spraying the parts with brake cleaner and/or PB Blaster to soften any gum and carbon. Then, using a small blade (like a putty knife or a sharpened flat screwdriver point) tap around the insert collar to pop it loose.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
