beemerphile1
Dec 10, 2012Explorer
AZSMOKER wrote:
professor95,
Thank you for your response. I don't have a meter to measure the draw from the chainsaw, are they expensive to get...
RollingCondo,
I'm at work right now, but the extension cord seems fairly heavy duty...
Check out the P3 Kill-a-watt for a good all around meter.
http://www.p3international.com/products/special/p4400/p4400-ce.html
You'll find lots of uses for it after you get one. They can be had for under $20
You would be well served with a 12 gauge cord or heavier. Some so-called heavy duty cords are only 16 gauge and about worthless for anything other than a trouble light. The gauge will be imprinted into the outer sleeve in tiny print.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
