MrRchitty
Apr 15, 2013Explorer
thejrod wrote:
Any tips for getting two inverters to sync via the parallel cables?
Mine just came in and it was a ***** to get them to sync. The second unit would never flash steady green.if I reversed the order of startup, the first unit would go into overload every time. Finally I put a load on the 30A receptacle with the one unit still flashing, then turned both off. Then fired up both of them at the exact same time, and they finally synced.
Seemed like a long and trying process to get them to sync...
Best explanation I could give you...
Parallel Operation
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
