MrRchitty
Jul 10, 2013Explorer
orionpaxx wrote:
Thanks, you know, sometimes you overlook the simple things
Mine are mounted in a food truck, makes sense that if I forget to
Turn off fuel it'll leak over turns and bumps back into filter.
Lets see if that solves it!
Ah, yes. Aren't you the one that had some issue a while ago? Anyhow, sounds like you are up and running, or have been, was curious how you made out. Anyway, have you been looking inside your units on occasion? Look at the wires. Any wires dangling and lightly rubbing against each other will wear through. I have had to cut and reattach a few on one of them and a reassessment has revealed other wires beginning to wear.
How have you been doing with using them on your food truck? Very fuel efficient and I'm sure the noise is tolerable.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
