MrRchitty
Jan 02, 2014Explorer
Dave H M wrote:
My genny (2000i) has a drain valve (simple screw) for draining the carb and checking gas flow. It also has a tube hooked to the drain that exits the bottom of the panel.
if desired I could just drain that baby dry via the carb drain on mine. :h
Great option.... However, when you run the generators, unless you need to shut it off right away, or will not be starting it in the next day or so, just shut the fuel feed off and let the motor use up the fuel rather than removing the screws and draining the carburetor. I'm on two, three and four years for each of my generators and not one carburetor issue.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
