MrRchitty
May 15, 2014Explorer
mfifield01 wrote:
I bought an 11,000 BTU Portable AC. It will start and run with ECON mode OFF. I can start it with ECON mode OFF and then flip ECON mode ON. If it cycles, it kills the generator. The watt meter shows around 950 when running. It read 21A as the max pull and about 8.9A running. I'm not sure how long it run on a tank. My other concern is that the Portable AC is large.
I turned the idle screw up just a pinch. It might give it just enough to start the air conditioner. I did that to both of mine and each starts a pancake compressor and an electric power washer on eco mode.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
