zuterbru
Jun 06, 2014Explorer
Why do you have to start your big AC unit in Econ mode? Econ mode is not there for that, it is for when you are running a small load so the engine does not run at high RPM unnecessarily. Saving fuel and being much quieter.
FYI, I found out the Spark Arrester needs to be cleaned quite frequently. You can get the manual online and it tells you how to do that. I used Carb Cleaner to clean it out, don't forget to clean the end cap. If you start seeing black smoke, clean the arrester.
Steve...
Steve...
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
