otrfun
Oct 15, 2014Explorer II
mdelleman wrote:Typically, the "running", continuous current output will nearly double when generators are paralleled; however, the increase in inrush current will be significantly less. Why? I have no idea. I've found inrush current only increases roughly 8-12% when two Honda EU2000i's are paralleled (when compared to one Honda EU2000i).
@otrfun
How much headroom/surge do these Champion 2000i's really have? If I parallel them do you get a little better surge capability?
Although I observed inrush current with paralleled/solo EU2000i's, an EU3000iS, and a Champion 3100/75531i, haven't had the opportunity to do so with a Champion 2000 inverter generator. However, there's a quite a bit of online anecdotal evidence that suggests the Champion 2000 inverter outputs significantly less inrush current than the Honda EU2000i (both solo and paralleled).
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
