otrfun
Oct 15, 2014Explorer II
mdelleman wrote:In the context of your reply, inrush and surge are completely different animals.otrfun wrote:If by paralleling the Champ 2000i's to get a safe continuous of 3000W (in the manual) Then add 100W inrush per gen for total of 3200W. Would it be safe to assume that since the Champ 3000/3500 starts the AC with hardly a blip the two 2000i's could handle the extra surge? Is an extra 100W surge capability per gen selling it short or about right?mdelleman wrote:Typically, the "running", continuous current output will nearly double when generators are paralleled; however, the increase in inrush current will be significantly less. Why? I have no idea. I've found inrush current only increases roughly 8-12% when two Honda EU2000i's are paralleled (when compared to one Honda EU2000i).
@otrfun
How much headroom/surge do these Champion 2000i's really have? If I parallel them do you get a little better surge capability?
Although I observed inrush current with paralleled/solo EU2000i's, an EU3000iS, and a Champion 3100/75531i, haven't had the opportunity to do so with a Champion 2000 inverter generator. However, there's a quite a bit of online anecdotal evidence that suggests the Champion 2000 inverter outputs significantly less inrush current than the Honda EU2000i (both solo and paralleled).
I know that real results are the only way just trying to figure out if it worth picking up another 2000i if I will only have trouble actually getting it to start the AC!
A generator's INRUSH current capability is its ability to output an increased amount of current for only a second or two (necessary to start an inductive load like an a/c compressor or motor), whereas, the "surge" capability typically mentioned in generator brochures/specs quantifies a generator's ability to output continuous current above it's normal, rated output for a limited amount of time, say, 15-30 minutes.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
