MrRchitty
Oct 15, 2014Explorer
otrfun wrote:MrRchitty wrote:Without standardized testing, it's difficult to know what a given generator is capable of generating (loudness & power) in the realworld--especially with inductive loads.
Otrfun, that's about it in a nut shell. However, champion is rated for 5 seconds at 2000 watts, while a Honda will do it fire 30 minutes. In rush is for 150 ms.
Honda clearly advertises their EU2000i as capable of producing 2000 watts for up to 30 minutes. However, you're saying the Champion 2000 inverter generator is only capable of producing the same 2000 watts for just 5 seconds?! If true (I have no reason to doubt you), this is a ridiculous difference in realworld capability.
Although you're setting a duration of 150 ms for inrush measurement, I observed one Honda EU2000i produce 53.5 amps of inrush current for almost a second (ECO mode off). For the sake of humor, one could use this result and simply shorten Champion's so-called 5-second "surge" test by just a second or two and claim the Honda EU2000i is capable of 6420 watts of "surge" output--lol!!
My numbers on the champion are directly from their manual.
The millisecond rating is from the professor who was close to one of the executives at champion. My personal conversation with them and another vendor says they're 400ms after a certain production and mine were replaced.
It makes a difference.
Go back several posts and you'll see where I've posted videos of them at work.
Supergen.com used to reprogram them for free to the latest version which fixes a few things.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
