wa8yxm
Nov 01, 2014Explorer III
PDI's converters were unique for several reasons, for one thing they came up with a design that used something called Zero Voltage Switching, This means they had to have higher quality transformers in their earlier models (Cause they would burn out regular ones) this also means less Radio Frequency Interference from them because if you use zero point switching there is no zero to generate interference with.. But of course. That is what you get when you have folks who care about RFI on the design team.
I am only one degree removed from PDI on two different paths (or was then).
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
