Chris_Bryant
Nov 01, 2014Explorer II
MEXICOWANDERER wrote:
Follow the PDF link above if you wish and familiarize yourself with a Gran Mal design, the converter with bleed resistor, relay, and capacitors so inferior, three years of continuous use rendered a finish voltage of 14.4 - 14.5 Pretty impressive nightmare for a "13.8 volts float charger".
That link is to the linear converters, not the ferroresonant. Here's the schematic for the 775-2 converter:
The linear converters were adequate when the only electronics were maybe a 12 volt black and white tv and radio- the charge circuit was regulated and adjustable, but the main output was unregulated and unfiltered. They didn't do a great job of charging, but they really did as well as most purpose bult battery chargers of the day- smart chargers were still a ways off.
The ferroresonant models were near bullet proof, and each different model had a different design voltage- I saw voltages from 12.6 to 14 volts spec'd. you can see by the schematic there really wasn't much to go wrong.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
