Gjac
Nov 01, 2014Explorer III
Chris Bryant wrote:Thanks Chris. I guess at 13.2 v it would not be a "battery boiler". I find that a few days floating on this Magnatek adds several days to dry camping once the B&D says ful. It also seems quieter than it was 10 years ago.Gjac wrote:
I have an 18 year old Magnatek 950 and a 40 amp portable B&D charger. I use the B&D to charge (2) 6v Sam's Club GC batteries quickly then float with the Magnatek for several days. Mine only puts out 13.2 volts once batteries are charged. Is this normal or is the lower voltage due to age? I don't remember if it ever got to 13.8 v when batteries were at 50% SOC.
Normally, low voltage on these means the capacitors on the resonant circuit are getting tired, but for maintenance I would probably leave it be. Note the capacitors are not that easy to find, as they are 660 volt (there is around 50-600 volts on the resonant circuit, so care should be used when servicing).
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
