Chris_Bryant
Nov 01, 2014Explorer II
MEXICOWANDERER wrote:
The only thing I can think of is that Magnetek had dozens of designs. Adding a 100uf cap on the relay resistor unit output raised voltage .3 volt If it were purely linear it would not have done that nor should it have kept the same output voltage with wildly varying input AC voltages.
That's just the charging circuit, which was actually an option, but it's an add on to the purely linear converter. They used a couple of different designs for that option, but I have to dig out my paper manuals to tell the difference. I do remember they were a different option letter in the model number, and had very different capacities- one was 3 amp, the other around 10 or 15 amp (nominal, in a perfect world, during periods of porcine aviation :)).
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
