MitchF150
Oct 06, 2022Nomad
TURN THE ANTENNA OFF (the wall plate with the switch, light, antenna connector and 12 volt outlet.. TURN IT OFF)
He said he did that in his first post...
Other than checking the TV input settings and such, get a cable long enough to go from the post to the tv and plug it in directly. Then see what happens.
That will eliminate the RV's cabling setup and then you can go from there.
Good luck! Mitch
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
