Pbutler97
Oct 07, 2022Explorer
wa8yxm wrote:
Well if it's a 5 year old other than Element someone suggested hooking direct from the park to the TV (not using the cables in the RV) I had to do that at one park.
NOW.. there is also the chance (Unless you already checked it) The park has a problem.
And one more that I have seen is a poorly dressed coax cable.. When they put the connector on (Sloppy job usually) they cut the center pin too short so it fails to make contact withsome connectors.. I've re-dressed many cables.
Furrion does not have a QAM tuner. Junk TVs and Furriob is now owned by Lippert, which is why the RV manufacturers use them. Advertised as
"Furrion offers a wide range of HD and 4K UHD LED TVs designed for use in RV, camper, marine or home. The energy-efficient 12 Volt and AC powered televisions offer excellent picture quality and are road-ready, built to handle vibrations and extreme temperatures."
LOL.....overpriced junk.
From the Furrion specs.
Broadcasting
Analog: NTSC
Digital: ATSC
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
