bsport's avatar
bsport
Theford toilet
Aria II toilet had it replaced everything time to junk , any idea as what to replace it with ? Need same bolt pattern if possible.
  • My wifey and I both have bad knees so I've been thinking about a hi profile toilet. I added a sprayer to my current toilet and a LOT of water goes down the drain when flushing AND using the sprayer... fresh water tank goes down and black water tank fills up fast! Does the Dometic with the mfgr. installed sprayer shut off the flush water when the sprayer is used? If not Dometic, does any other brand do that? Thanks,Craig
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Ed_Gee wrote:
    Dometic 310/311 or 320/321 . Keeps it simple, functional, excellent quality, ease of use, comfortable, and reliable.
    X2
  • Thanks for help going to change as soon as I get home.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The good news is there are basically 2 bolt patterns.
    Imagine a clock face over the hole in the floor with the 12:00 position pointed straight forwared as you sit:
    One pattern is 3:00 and 9:00 (that's the 2 bolt pattern)
    One is 3:00 9:00 6:00 and 12:00
    The flange (The part in the floor) generally accepts either pattern.
  • Dometic 310/311 or 320/321 . Keeps it simple, functional, excellent quality, ease of use, comfortable, and reliable.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 20, 2026
