PaulJ2
Oct 19, 2015Explorer
Salvo wrote:
I don't see why it shouldn't work. You need schematics. You may be able to fool the emc. Even if you get cel, nothing bad will happen. It's not going into limp mode for that.
Or you can fool the emc the bat voltage is low. Put a pot on the voltage line going to the emc. The emc may have a battery voltage sense line.
My Jeep Cherokee has a temperature sensor at the battery. As temperature increases the charging voltage drops. Another way to do it I guess. Mounted underneath the battery tray and touches the bottom of the battery. I don't know the operating parameters of it though.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
