MEXICOWANDERER
Oct 19, 2015Explorer
OUT OF STOCK but still interesting...
http://store.alternatorparts.com/quikcool-alternator-cooling-system.aspx
"S" is the voltage SENSE terminal. It is also a field power terminal so do not restrict current. Use a 10-amp Shottkey to increase voltage from the factory 14.5 setting (temp slumps voltage via thermistor voltage divider biasing). Switch in the Shottkey to raise voltage by an average of .4 - .5 volt. A DPDT dash switch will work fine. Center off position on the alternate switch leg is for ign which turns the alternator off.
Hope this helps
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
