Salvo
Oct 21, 2015Explorer
There you go. Looks like a good design and easy to build. Use a standard TO3 heatsink, or contact the designer.
Still need to know the resistor value to fool the emc. The resistor simulates the field load.
This design just looks at battery voltage and activates alternator when voltage is low. As mentioned earlier, you can use existing regulator and lower input battery voltage (using diode or pot) and get similar results.
landyacht318 wrote:
http://www.amsterdamhouseboats.nl/voltage_regulator.htm
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
