jasdms wrote:
I have a atwood water heater, it will not light, not on electric or gas, I think I found the problem, the thermal cut off fuse, my question is can you run contninuty  through this fuse??  I tried, it will not read on meter
When you say "won't read on meter" what do you mean?
If by "won't read" you mean it reads open circuit, then replace the fuse.
If by "won't read" you mean it reads 0 ohms, then it is fine.
As always, before you replace a fuse figure out why it blew.  This is an important fuse not to bypass, because it will keep your camper from burning to the ground...
