TomG2ExplorerFeb 21, 2022Thermal Glue ApplicationThe spring clip that holds the thermostat to the tank on my water heater is failing. Would thermal glue work to hold it in place and what brand would you recommend?
1 ReplyReplies sorted by NewestCharlie_D_ExplorerFeb 21, 2022Can't help you so why not try.I have used J.B. Weld on many applications needing to attach metal pieces to each other.Good Luck
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentDometic fridge RM2652 tripping thermal sensorThermal BreakerTrip planning applicationFlooring GlueLiquid Roof application
