vermilye
May 18, 2020Explorer II
I hope you solve the problem. I had a RM 2510 in a previous trailer, and while I liked it for dry camping since it only used 12V to fire the igniter, I had multiple problems with the thermostat & had to replace three of them, 2 for electrical failure & one for gas, but all kept it from cooling, not too cold. There is a mechanical connection between the diaphragm in the thermostat body & the electrical contacts that jammed off in my case; I suspect it could jam on.
I like the instructions for replacing it without removing the refrigerator, but I had to pull it all three times. By the way, keep the door gasket in good shape. You cannot replace it - requires the entire door replacement.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
