bb_94401
Oct 11, 2015Explorer
Replaced mine with a Classic Pro 70 series, 7 day programmable, single stage Emerson / White-Rodgers (#1F78-167). Equivalent current model would be 80 series 1F87-361. Closest model 70 series is 1F78-151 (5/2 day).
Chose the White-Rodger due to lowest set point being 45F. Good documentation / installation instructions. Uses 2 AAA batteries for operation that need replacement.
Eliminated the AAA batteries and wired in a DC/DC converter 12VDC to 3VDC connected to 12VDC system. Advantage was didn't have to replace batteries at worst possible time and didn't need to re-program the thermostat due to loss of contact of batteries while bouncing on washboards on FS roads (contact springs weakened with time and household thermostat battery holder wasn't designed with vertical acceleration in mind).
Tape or reusable craft putty adhesive works well if you want to go the mechanical route to hold batteries in place (i.e. HandiTak)
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
