Hybridhunter
Oct 11, 2014Explorer
Thermostat upgrade - 2 stage w/ heat strip - fan speed issue
So I'm upgrading my new Coleman Mach 1 Air Conditioner with heat strip, to an external digital programmable multi stage thermostat.
I find all aspects pretty straightforward. I am trying to devise a way to have it automatically go to the higher fan speed for the second cooling stage. Some folks with the Dometic / Hunter combo have just hooked up the second stage to the higher fan speed. Dometic must have some interlock on the relays, or both relays and windings would be energized at the same time. I see 2 problems there.....
1) There doesn't appear to be an interlock on the relays for low and high speed, so that could do some damage if they both engaged.
2) If I just use a switch on the fan wire and left it the thermostat fan "on" with the 2 pole switch on the high position, the same issue would appear when using the heat.
