- theRoadrunnerExplorer
Hornnumb2 wrote:
If you are near houston texas, i would make you a great deal on a new one. Purchased for mine but won't fit.
Nowhere near Houston - near Cincinnati right now. - Hornnumb2ExplorerIf you are near houston texas, i would make you a great deal on a new one. Purchased for mine but won't fit.
- darsbenExplorer III believe the serial and model number are either above or below the pedal. Thetford customer service is very helpful identifying what I needed
Chris Bryant wrote:
A lot depends on the model- I would bet you have an Aqua Magic IV, and that fix would be a cable replacement package- an easy and cheap fix, Thetford p/n 24571.
But.. there are a lot of 2 pedal Thetford models, all using different parts.
That is what I am afraid of... I am not in Lakeland, Florida at the moment but when I return I will have to make a decision!
Thanks... :C - Chris_BryantExplorer IIA lot depends on the model- I would bet you have an Aqua Magic IV, and that fix would be a cable replacement package- an easy and cheap fix, Thetford p/n 24571.
But.. there are a lot of 2 pedal Thetford models, all using different parts. - theRoadrunnerExplorerThanks - I'll check into a new toilet but also check into parts now that I know they could be available.
Appreciate the replies... - darsbenExplorer III just repaired my pedals with a kit that included all the working parts. It was a simple three screw replacement. It could be the spring that controls the pedal slipped of the hook or broke.
IIRC kit was under $100.00 shippped - BarneySNomadMoved to Tech Issues forum from DIY.
- westendExplorerYes, parts are available, at least they were, still, for an Aquamagic, which predates yours by a number of years.
I repaired my old throne but if I had it do again, I'd replace the whole thing. A new toilet can be had on E Bay for around $125-$150.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
