StuartT
Dec 05, 2013Explorer
Old-Biscuit wrote:
No adjustments....fixed cable length.
Cable slides into slot of water valve drive arm and is held to pedal by a 'ball'
Weak or loose return spring.
Return spring clips to drive arm and is held to toilet by a screw.
If you have room you may be able to check the return spring without removing toilet.
Pull the shroud off and have a look.....two bands in rear hold shroud in place.
Got it. Will pull that shroud this weekend and see what is going on. Thanks for giving me the heads up on what to look for.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
