StuartT
Dec 06, 2013Explorer
codelld wrote:
Stuart, I had the same problem on my Aqua-Magic. If you take off the shroud you will probably find that the small wire linkage that pulls the water valve has worn through the water valve drive arm that it is attached to. Check a parts list and replace the arm and while you have the toilet taken apart, you might replace the ball seal. The toilet is a lot easier to work on if it is removed from the floor.
Went over to the storage building this morning and it looks like you are spot on Dennis. Am ordering the parts today including the ball seal. Thanks for the post.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
