Thunder_Mountai
Dec 09, 2016Explorer II
dougrainer wrote:
The Toilet has a 2 year warranty. Does the water drain out while camped or while driving? On the back of the toilet, you will see a "Y" hose that is connected to the 2 fill/flush nozzles. Then you will see the LARGE 1.5 inch discharge hose (the J loop). The TOP of that loop MUST be even with the flush nozzles. If NOT, then you have the siphon effect draining the toilet bowl. Look at the link. pics I-1 and I-2 are not correct for your install. Figure A is close. Look at item 6 page 10 to see how high that hose should be. Doug
http://www.thetford.com/wp-content/uploads/2015/01/38996A-TecmaSilenceRV-Eng.pdf
Thanks! You've been more helpful than Thetford. I think Winnebago didn't install correctly. Will pull stool and check diagram.
