j-d
Feb 14, 2014Explorer II
A friend's Dometic was freezing stuff. I unplugged the Thermistor (that piece that clips onto the fins mentioned above) at the Control Board and tested it according to the service manual. Tested OK. I left scratching my head, what next? Friend reported "You Fixed It." What I decided was the little pins on the connector had corroded, lost contact, and when I unplugged/plugged back, must have scraped them clean.
You don't say which fridge it is, but if the Thermistor in a Dometic fails "open" (and Unplugged is the Ultimate Open), it goes to max cooling and doesn't know when to stop. Can freeze the fridge section.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
