Old-Biscuit
Feb 15, 2014Explorer III
LynnandCarol wrote:
Of course there is no adjustment for the fridge temperature
OP stated 'no adjustment'
Not all fridges have an adjustment for temp settings on upper panel
Temp control is pre-set and minor adjustments to temp in food section can be accomplished by movement of thermister on fin
Snip-The-Tip is a thermister repair kit for Dometic models
Instead of removing bad thermister and trying to pull new wiring from food section to lower control board you 'snip' the old thermister off, wire in the new thermister which comes with a rheostat to make temp adjustments
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
