Bobbo's avatar
Bobbo
Explorer III
Mar 20, 2016
Thinking about solar
DW has decided to downsize since our kids are all grown and gone. We are thinking of going from a 32 foot Class C to a Class B.
We are looking at a Roadtrek Zion.
Now, to the question.
The Zion comes with a 400 amp AGM battery. They have an option from the factory of 200 watt, 270 watt, or 300 watt solar on the roof. How much do we really want for a single 400 amp AGM battery?
There is less than $800 dollars difference between the 200 watt system and the 300 watt system.
  • You can't have too much solar, regardless of battery size. Any properly designed system will have a charge controller that will prevent over charging the battery. It won't matter if you've got 100 watts or 1,000 watts.
    Solar panels only cost about $1 - $2 per watt. A 300 watt panel shouldn't be much more than $350. A really good high end charge controller would be about $500. If the prices Krumm posted are true they are charging way too much for this option.
  • Their solar option is over priced. Also the battery is really a 180 Ah. Took a lot of digging to find that. The 400 number must be Cold Cranking Amps. Haven't seen the Zion yet but over all it may be a better choice then the Travato 59K we test drove the other day. Price is about the same.
    I'd go with 300 to 360 watts of solar and DIY.
  • Looking at the Trek website...
    200w Solar Package $2,730
    300W Solar Package $3,510
    You might get better value for your money by doing the battery upgrade to lithium and then buying a 3rd party 400w solar kit for ~$800
  • $800 for an extra 100 watts just seems like a lot.
    What is the total option price?
    Do you have any inclination to install solar yourself or shop an aftermarket installer?
    Yes a general rule of thumb would be 300 to 500 watts solar for a 400 a/h battery. Depends on use also. Are you going to be off grid a lot? Winter in the shade will still be tough with 300... summer in the south west may only need the 200.
    Do you have solar now? If so how is that working?
  • Depends on what your power use is going to be. Inverter?
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 04, 2025
