LittleBill
Mar 22, 2022Explorer
Krusty wrote:
Wow, hope you have a good fire extinguisher handy. Possibly you could remove all the related light fixtures and inspect to see if the insulation on one of the wires might be wearing through on a sharp piece of aluminum siding or something?
I did, they did not design them at all to be serviced. the hole is less then 1 inch, and the connections are soldered to the wire which has 0 slack, its actually taught tight.
I will do so much damage trying to work it from the outside, that its just easier to drill straight into the cab, and make a new harness.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
