Mike_Schriber
Jan 26, 2017Explorer
This is pretty much my thinking. Any moisture and volatiles will boil off since the engine is run at operating temperature for extended periods of time even though the total mileage ends up being relatively low.
I've put 40,000 miles on in six years but recently I haven't been racking up the miles quite like before.
I agree that an oil analysis is the only way to know for sure.
Mike
Mike
DrewE wrote:
In your (Mike Schriber's) case, I hardly think it matters too much because you're never going to approach wearing out the engine at that pace. It's up there with concerns about rotating the tires on most motorhome when said tires are going to need replacement due to age rather than treadwear.
I think the main concern for the age limit is that putting few miles on the vehicle is usually associated with short trips where the engine doesn't get up to temperature and so many contaminants that would otherwise boil off just accumulate. That's not really the case for you (or most motorhomes, really), so the time limit is probably not very important. Oil itself doesn't have a particular shelf life after which it goes bad or sours or something, at least not in the timeframes we're talking about.
