time2roll
Jan 26, 2017Nomad
westend wrote:There is nothing to read between the lines.time2roll wrote:A bit further than what?
Every single post of an oil analysis that I have read has mentioned that next oil change can be extended a bit further.
Never read a post where the oil change was well past-due by analysis. Never read about tons of moisture, acid, soot, fuel, metal or any other boogyman wrecking havoc with the oil.
You believe that oil has an infinite lifetime? If it is all hogwash or boogeymen, don't change your oil.
I change my oil based on miles only and I go twice the distance recommended.
IMO lots of people are changing far more frequently than needed.
