I applied on my rubber roof and over the shower skylight. The skylight was cracking and put a 1/4 inch layer of the stuff. The rubber roof did great. Easy to apply. Anybody else used it?
Read the manufacturer's technical data sheet and it clearly warns that use on EPDM rubber membrane "may cause warping" - exactly the reason a product like Dicor self leveling lap sealant which is designed specifically for use on EPDM should instead be used. ;) Why try to reinvent the wheel when a proven product like Dicor is so readily available? :h
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
