DAS26miles
Jan 19, 2018Explorer II
MrWizard wrote:
yes you can use
it has its own controller
the panel voltage does not come into play
its the output voltage to the batteries
just like converter and alternator, the output sides all 'play nice' with each other
I have disconnected the controller on the Renogy suitcase and use the existing wiring and Anderson connector. I added an Anderson connection mounted near my batteries and controller for the roof mounted panels. Now easily able to attach portable directly into wiring before controller with disconnect switch.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
