DAS26miles
Jan 20, 2018Explorer II
Tom_M wrote:DAS26miles wrote:The Dokio 200 watt mentioned consists of four 50 watt panels connected in parallel. This has a Voc of 22.5 volts which is typical of a 12 volt panel. If your existing panel is 12 volt you can parallel this panel with yours if your existing controller can handle the added current. Or you could use this panel and controller and connect directly to your batteries using the included battery clamps.
I have disconnected the controller on the Renogy suitcase and use the existing wiring and Anderson connector. I added an Anderson connection mounted near my batteries and controller for the roof mounted panels. Now easily able to attach portable directly into wiring before controller with disconnect switch.
My controller is the the 30amp Renogy Adventurer. I may upgrade to a MTTP depending on how much more amps I can get out of the existing panels.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
