Tom_M1
Jan 21, 2018Explorer
DAS26miles wrote:You will not gain much on a 12 volt panel configuration. MPPT's big advantage is using panels that are higher volts. This can be accomplished by using a panel that is 24 volts or higher or connecting panels in series. If panels are connected in series, they must have similar current ratings. If connected in parallel, they must have similar voltage ratings. The portable unit mentioned previously has panels that can not be easily reconfigured.
My controller is the the 30amp Renogy Adventurer. I may upgrade to a MTTP depending on how much more amps I can get out of the existing panels.
If you want a better PWM controller you might want to consider the Grape GS-PWM-40BT. It's 40 amps and has Bluetooth. Home Depot is selling it for $59.98.
40 Amp PWM Solar Charge Controller with Bluetooth
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
