MrWizard
Jan 23, 2018Moderator
as promised Pix
Click For Full-Size Image.
Hanging on the side of the RV, i put the controller in the shade under the RV, i intend to lengthen the solar feed wire and shorten the battery charge wire
the got the suction cup hooks at the 99cents store
if they fail i will look for better ones online
i looked at the picture, saw the stretched D-ring
and replace it with a key ring
have to go to the hardware store and get a few key-rings
the D-rings are NOT strong enough for the appox 11# weight
11# is light for 200 watts, the size is about right for 200w
but the D-rings are TOO Small
any way preliminary feeling is, i like it, the controller even has (2) lithium battery settings, not that i need that, but thought i would put the info out there
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
