BFL13
Jan 24, 2018Explorer II
With that shape of array, it can be difficult to set it up to twirl as well as be tilted, but there is another way to get the same effect that could be easy, depending on the whole situation.
Orient the array lengthwise N-S tilted up, and be able to flop it sideways or be flat. In the evening you flop it to the East, ready for morning. If high noon is 12, then from 11-1 have it flat, then flop it to the West.
I had a way of doing that in 2012 and it worked out great for AH haul. It would not need to be anything so complicated for Mr Wiz's situation. He needs a lightweight quick set-up and breakdown that won't blow away, and is easily stored in the MH, but that is not impossible.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26065604.cfm
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
