Davidlee64
Aug 30, 2017Explorer
I found a diagram that gives me the idea that the neg side to the battery is the chassis. But the diagram shows chassis ground, and a cable from the ground buss in the converter to the battery. The lack of that neg cable is what threw me. I will be adding a neg cable when I install the new converter.
The current battery cables to the converter are a double 14 gauge positive, and a 14 gauge wire to the jack motor switch. I have already ordered 8 gauge 90° C wire and lugs to run from the batteries to the converter. I suspect the junction in the positive wire is a circuit breaker. I need to pull it out so I can see it and verify what it is.
