Davidlee64
Sep 07, 2017Explorer
I don't believe the electrical system has been modified from original. But it has no rhyme or reason either. Depending on where you look, the battery compartment wires are red (+), and black (-). Except for the positive lead between the 2 batteries is green with red shrink on each end. In the converter box the 12 V positive (+) feed wires to each circuit are black, black with white stripe, red, and blue. The battery leads at the PC board are red (+) and green (-). I tracked which fuse goes where by process of elimination. Pull a fuse, then see what goes off or no longer works. Do this one at a time, and write everything down. If I need to physically locate wires in the walls, I use a tone generator.
