joshuajim's avatar
joshuajim
Explorer II
Nov 16, 2020
Time to replace A/C
My Brisk Air is now 9 years old and needs to be replaced. My question is if I go to a Brisk Air II will my current Single zone thermostat still work. If I decide to go with another brand, what are the ramifications of installing a different thermostat with the existing low voltage stat wiring?
Finally, what unit looks to be the best 13.5 at this time.
  • 1320Fastback wrote:
    I put a Atwood Air Command on our trailer. Thermostat is built in and you have a remote control to adjust if you can not reach the control panel on the AC itself. Only wiring needed was the Pos,Neg and Ground.
    Just to clarify for you. There is no such thing as POS/NEG on 120 volts. There is HOT(black)/Neutral(white) and ground. Doug
  • When I replaced my Dometic AC on my Class B I went with their high efficiency unit which they do not seem to advertise. It is great and I can run it with my Honda 2000 if needed.
  • I put a Atwood Air Command on our trailer. Thermostat is built in and you have a remote control to adjust if you can not reach the control panel on the AC itself. Only wiring needed was the Pos,Neg and Ground.
  • When you replace a Brisk air- you are only replacing the upper unit. The tstat and controls are separate from the upper unit and will work with your new replacement. Doug
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I would upgrade to a 15K modern 15's use about the same amount of power and give you more cool. You will need to check but with a single zone odds are fantastic your existing stat will work. however they are not 100%.
Having RV issues? Connect with others who have been in your shoes.24,353 PostsLatest Activity: Jan 23, 2026
